Black Bart
If you trace the wire from the key switch to the starter you will find a relay if it has the kit.Hey, Thanks alot for the great information, it has 1,200 hours not 2000 btw:wink:. I'll definitely check the deck and the hydro fluid. I have a question though, how could I see if it has the starter kit on it? Thanks again for the great advise.
I put one on my 180 when it was only a year old the relay is a small black plastic square box.
