G,day,
Someone may be interested, fitted a genuine kawasaki heavy duty air filter kit to my new hustler mower with FR651 engine.
I love the mower but don't love the air filter set up, very dusty here!
I spoke to the kawasaki agent in australia regarding warranty and any requirements to rejet it, doesn't affect warranty and was told no need to touch it.
Had a nice conversation with bertsmobile1 from this forum, thanks mate!
Said i would test inlet restriction with the std setup and the new setup and post some results on here.
Tested the inlet restriction, virtually no difference, maybe ¼ of an inch of water more with the Donaldson kit but as the std filter gets loaded more it will increase inlet restriction.
Inlet restriction was tested with a cat 1U5470 engine pressure group plumbed into the inlet elbow, kit fitted spot on,everything in it and a nice sturdy mount as you would expect with genuine parts
Comes with the FX top cover and mounts, another good feature is the new top cover has an access cover above the fins on each head for blowing out.
Cheers
Paul
Cheers
Paul
brand new std filter and brand new unoiled pre filter.jpg76.8 KB · Views: 9 -
