Cannot find this carb ... please help!!!
shodges7977
Hey friends, complete NOOB here. I inherited a John Deere 220 reel mower with a Kawasaki 124cc engine ... the carb is toast and for the life of me I cannot find the correct replacement. It's a Keihin carb and there is a number stamped on the top "32367 J1 26" (I assume it's a 1 and not an i ??) I've attached some pictures. The bolt hole openings are 1 11/16" apart. Any ideas??
Post all engine numbers and we will probably be able to help you out. Have you opened the carb up? Many times the cover of a book does not indicate how good it is. May just need a good cleaning and rebuild, not a complete replacement.
shodges7977
yeah someone had already opened/damaged the carb ... and the bowl is dented and leaks - i definitely need to replace it.
the only Kawasaki engine numbers i can find on the thing: "Family I.D." SKA124U1G1RA ... "Code" FE120G-BS01" ... "E/NO" FE120G042566.
That particular carburetor is NLA and was used on the FE120G-AS01
But for the FE120G-BS01 the carburetor is supposedly still available under PN 15003-2718 with a list price of $164.09 US.
shodges7977
ok thanks. i plugged that PN into eBay and immediately found the carb (even though i had SCOURED eBay previously) ... man i cannot thank you enough!
Mikebeck31
How did that carb work out for you? In the same boat. Missing a carb for the same engine
