pilotbuddy
Grasshopper front mount is what I suggest for getting around trees. The deck tilts up for easy maintenance. They are built like a tank and ride way better than a Scag.
DITTO'You've enough property to qualify for a small tractor..I've an 8n. 1948. Then you get a bushhog, 60"
So now you have a tractor for not only cutting the grass, but with the purchase of a box blade and
landscaping blade you can keep that gravel drive nice and tidy...
So we just got a new property that will need to have 6 to 7 acres of bermuda mowed. Lots of trees, I mean like well over 100, most have really large mulch circles around them.
Right now I live on 3 acres, most of which has fescue and I mow that with a Freedom Z 54 inch. I'm guessing I'm going to need something much larger for the new property.
What size do you recommend?
My Scag dealer said $14897 for a 72 inch Turf Tiger 2, $13308 for a Cheetah 2 72 inch, and $9499 for a Tiger Cat 2 61 inch.
Would the Tiger Cat be enough? That is the only one they have available right now.
Personally I've been really happy with my Scag so I'm not sure I want to consider other brands, but are there other brands I should look at?
Thanks.
Wife and I live on 25 acres in Texas. I cut about 6 acres with my SCAG Tiger Cat II 61” Kawasaki and another 10 acres or so with my Mahindra 25/55. I could probably cut it all (time permitting) with my SCAG but with the hog problem we have, there are some areas with rather large ruts and I don’t want to abuse my SCAG when I have other ways of cutting.So we just got a new property that will need to have 6 to 7 acres of bermuda mowed. Lots of trees, I mean like well over 100, most have really large mulch circles around them.
Thanks.
