Hi Guys,
I have a 20hp vtwin intek 40g777-0112-e1. the ignition coils are Rotary 31-11578. My problem is that when you touch the kill wire to the block it will not kill the engine. i pulled the
top shroud and touched the kill terminals on both coils with a probe and it killed the engine. I swapped 2 different kill wires and still didn't kill the engine. I tested the harnesses with a meter and they all tested ok. Out of frustration I pulled the coils off another mower and put them on this engine and it works like it should. Do these Rotary coils use a different # kill harness? I feel like I'm missing something simple here. I got this engine to replace a blown engine on one of my mowers but I don't want to swap out until everything works like it's supposed to. I hate to get new coils and it be something simple i've missed. Engine is mounted and being ran in a test stand until I'm ready to swap. Thanks in advance.
