- Sep 24, 2017
- Threads
- 280
- 6,766
I'd sue you but the Texas Hammer isn't returning my calls.?
From the outside, yes. But I thought I should fill in the hole on the cylinder side.and I thought this hole would be plugged with a bolt?
What for? That space will lower your compression by like 0.00001%.From the outside, yes. But I thought I should fill in the hole on the cylinder side.
I just thought I had to. I didn't know any better. Good to know. I'll clean up any burrs and put it back together. ThanksWhat for? That space will lower your compression by like 0.00001%.
