gonzo7
- Apr 5, 2020
- 5
I have been "gifted" an old Briggs and Stratton engine in a Craftsman walk behind string trimmer. It is an L Head motor. It was run w/o oil and fried the engine (oil was ugly), and now it won't start.
I'm about to tear it apart to rebuild it but was looking for advice on what is likely the culprit and what I should be replacing. I'm assuming the tappets got worn down so the valves aren't opening and possibly the camshaft is worn out as well. Should I replace the valves as well? Anything else to consider?
Also, I can't find the engine model number anywhere..It is not where the B&S site says to locate them. It is an old engine (probably 20 years old) but hardly run, so almost like new.. except for the fried part.
Any thoughts and ideas are greatly appreciated.
-g
-g
