Bottomline:
remove plug, spray carb cleaner or starting fluid into cylinder through plug hole.
reinstall plug and plug wore.
start engine. If you get nothing, engines spins but does not bang or smoke then there is NO SPARK.
pull the plug, lay it so the side of the bare plug is toching the engine try to start, if no spark is seen then it's an ignition problem, check coil, wire, maybe defective plug.
with the plug removed, crank the engine, feel for air to blow out of the plug hole, if no air blows out then you have valve issue and/or piston is not going up and down.
With the plug removed, put a long pencil or long but thin wood dowl into the spark plug hole so that it is touching the top of the piston. sping the engine b hand and see if the pencil moves up or down, if it doesn't move then there is a crank or connecting rod issue..
The engine is very very basic.. no smoke, no bang try starting fluid (remove the air cleaner first) if it tries to start or bangs then spark is good. however spark could be improperly timed. the timing is done by the magnet on the flywheel, check the "crankshaft Key" makesure it is good. if it sheared then the flywheel will be in the wrong position on the crnk nd will spark the plug but at the wrong time..
