About two months ago, the bearings in the electric clutch on my DLT2000 917.272246 were seized and it would always engage the blades even if the PTO switch was not on. I replaced the clutch then, and things worked fine for a while, though I did notice that something would squeal when first starting up the blades. Mowing yesterday though, the blades suddenly disengaged and would no longer engage when I turned the PTO switch off and on. I noticed that the clutch was extremely hot and I see sparks in there when the PTO switch is turned on.
I plan to take the deck down and look at the clutch again as well as examine the pulleys and belts to see if I can see anything amiss. If anyone has any thoughts on what might be good to look for, I would appreciate it very much. I'm bummed that I might need a new clutch and I am not really sure why they might be seizing up.
