echo trimmer
pasquot
i have a situation with my trimmer. 58v string trimmer. i have a problem while trimming. i keep getting grass clippings caught between the line head and the guard to the point where the trimmer stops turning. can anyone suggest to me how to avoid that situation? l spend more time trying to clean out the grass clippings with a pick than i do trimming. VERY FRUSTRATING!
JoeFriday
Can you post a photo of the problem?
7394
that's a new one to me. a pic of it clogged would be helpful.
tank1949
Usually very high grass will cause mine (SRM 230) to bind up as well. Try blade on the high/thick stuff.
MParr
It sounds to me that you are cutting tall grass and weeds. If that is the case, start trimming at the top of the grass and work downward.
