acres47591
2013 725D. My 30A master fuse blows when I try to start the engine hot. Usually starts fine when cold. I had the starter checked and replaced the solenoid, but still did same thing. Did some testing and found that the solenoid trigger wire only had 8-9 volts. Changed the ignition switch. Now I have 10.8 volts on trigger wire, but still blows fuse when hot. Not sure where to go next.
