bostonbear
Hello. I'm new to the small engine repair scene.
I have a John Deere L118, B&S Intek V Twin 407777-0131-E1.
I just finished replacing a broken connecting rod and damaged piston. The engine has about 280 hours on it. I suspect the damage was from a mouse house on the cylinder head fins. That and probably low oil.
Anyway... it runs again. Seems fairly solid. I adjusted the valves and even took the carb apart and cleaned it. Idle RPM is about 1750... full throttle no load about 3100 RPM.
Here's the issue. When I go from idle/low and just slam the throttle lever to high... the engine races and or hesitates a few seconds... burps out some white smoke... and then runs fine.
Any clues? It runs fine beyond this fairly minor issue. I assumed the carb was dirty but I cleaned it out fully... no luck,
