mahaffeymj
Deck was bad on a HR215K1SXA and replaced it with an extra one I had. Started up but blade ran on starting and would not disengage. Two things I thought might be wrong was: cable needs adjustment and wondering if torqued the special bolt 90021-va4-000 too tight (did not see recommended torque value). These are the bolts that have the springs inside. Has anyone ran into a similar problem or offer a solution? Can anyone see the torque value for the bolts? TIA
