I've about a 15-year old Craftsman lawn tractor (917.275760) with a 18.5 hp OHV Intek engine (engine model 31p777-0299-e1) that only runs on choke when hot.
I can keep it running if I run the mower deck engaged as the momentum of the spinning blades keeps it running; if I disengage the blades, it will die on choke.
This started last year and I thought it might be valve clearance so I adjusted valves over the winter.
Same issue this year; I redid them a week ago and same symptoms. Hopefully, I did it right, some concern about which valve is ex vs intake but I'm pretty sure I got it right:
The carb has a restriction of adjustment of the mixture and changing it doesn't seem to help much.
I haven't taken off the carb bowl yet as I don't see dirt as a problem since it runs well for about 30 minutes and then starts acting up.
I'd appreciate any thoughts on how to investigate/fix.
| upper valve | 5-7 exhaust valves |
| bottom valve | 3-5 thousandths intake |
