Hydro Meltdown!
shoez
I went out today and bought a used 62" side discharge deck for my 26hp walker mower. Got half the yard done and one of the pulleys melted down! Any idea on what happened?
Thank you in advance!
Bearing lock up.
mechanic mark
Bearing failure, I would remove & inspect all idlers & belts for replacement.
Paul54
As mechanic Mark says , siezed failed bearing , its all blue excess heat , possibly not enough grease, or it got washed out during cleaning of machine
On another note, might wash that filthy engine off. All that dirt will insulate the cooling fins and over heat the engine. Cooling fin cleaning is a yearly maintenance routine.
shoez
As an update....
Bearing failure. Took it to my dealer replaced all pulleys, and replaced belts. Hydros we're fine. Working like a champ. 2008 year model with less than 300 hours.
Thank you all!
Tnx for closing out the thread. Glad things turned out well.
As an update....
Thank you all!
Clean your cooling fins. If you don't it can take out your engine.
I recently repaired a Walker mower where the hydro radiator (oil cooler) was half blocked. It cause the oil to super heat and the way Walker design the system with this cooler over the engine proceeded to overheat the engine causing a head failure along with a damage engine fan and shroud.
