Craftsman Mower unable to start
NovaScotia1989
Hi guys, first time poster here.
I am having trouble starting my mower this season.
It ran a dozen times fine. Now I can’t get her to run.
The engine spins roughly once as the key is turned and stops.
Craftsman 917270850
Briggs and Stratton 461707-0145-E1
There is a new Lawn and Garden battery installed as well as starting solenoid.
could my issue be the actual starter motor? Or by creeping the forum could it be a valve adjustment issue?
Thanks in advance for any advice.
Born2Mow
I am having trouble starting my mower this season. It ran a dozen times fine. Now I can’t get her to run. The engine spins roughly once as the key is turned and stops.
It does sound like the compression release is not working due to valve adjustment.
NovaScotia1989
Okay, that will have to be something I check into tomorrow afternoon with the right tools.
Any idea what the feeler gauge should be set to and what the torque spec is buttoning everything back up?
Scrubcadet10
Moderator
Staff member
On the opposed twin, (according to the model number provided) the camshaft doesn't appear to have a compression relief mechanism.
To adjust clearance on a flathead you will need to remove the valves and grind the tip of the valve. A LITTLE BIT AT A TIME.
only if the clearance is out of spec.
NovaScotia1989
Also how involved is the valve adjustment on this engine? Am I biting off more than I can chew?
NovaScotia1989
Is there anything else that may be the issue? Sounds extremely involved
Scrubcadet10
Moderator
Staff member
Nope, you got to slightly grind down the valve... little at a time, again, that is only IF the clearance is out of the specified range.
you have to remove the valve cover, which is a little plate on the top of the engine, on each side, i would purchase a flat head engine valve spring removal/installer tool, (tons easier), remove the cylinder head(s) which is simple. slowly grind the valve small end, a little, and when i say little, a little at a time. you can take material off, but you can't put it back on. check, clearance, grind some more, check clearance, grind, check, grind check until it's good.
install a new valve cover gasket, as well as head gasket.
If the valve clearance checks out GOOD, i would get a volt meter and start checking voltages. it is possible to get a voltage drop in the Main + wire due to corrosion in the wire or bad ground connections. Or even a bad starter.
NovaScotia1989
If my engine manual and my riding mower manual have different clearance specs which one do I use?
NovaScotia1989
what level of dicolouration and grim is usually on the valve heads? If any
