GCV160 vs GCV170 Ignition Coil
ktrwn
I'm pretty sure the ignition coil on my HRN216 (GCV170 engine) is the reason why it does not start. I have had trouble finding a OEM replacement (part # 30500-Z9V-003). A source I did find sells them north of $80 and they have to get them straight from distributors.
What are the implications of substituting said coil with one from a GCV160 engine (part # 30500-Z8B-903) which I found for $20. Visually they look nearly identical from pictures, but wanted ask here if there could be any issues I should know about.
Scrubcadet10
Moderator
Staff member
The two sources for Honda parts that I have both show the 30500-z9v-003 out of stock and both list the price as under $10
ktrwn
Hey Ilengine,
Can you give me those two sources if you don't mind?
@ktrwn My two sources are dealer distributors and don't sell to the general public.
30500-Z9V-003 was superseded to a new part number according to parts tree,30500-z1t-023 and is $42 at Parts tree, https://www.partstree.com/parts/honda-30500-z1t-023/
or $40 at jacks, https://www.jackssmallengines.com/jacks-parts-lookup/part/honda/30500z1t023
with an aftermarket alternative https://www.jackssmallengines.com/jacks-parts-lookup/part/raisman/8060108
Double check that supercession. Partstree has a habit of throwing several parts up when they either don't have that part number or will list similar part numbers which may or may not be correct.. That part that you posted comes back being used on a FC600 tiller and two 2500 watt generators not a push mower engine.
Also original PN appears to be still available.
ktrwn
Quick Update here: I was able to replace the coil part # 30500-Z9V-003 which is listed as $75.24 plus shipping
with this one (part # 30500-Z9V-004) for $24.31 plus shipping
Now it is starting up flawlessly. They look nearly identical, I assume the change from -003 to -004 may be due to a newer or improved part? Either case, I did end up saving money which was the main point. I hope this helps other folks.
Scrubcadet10
Moderator
Staff member
Thanks for coming back and letting us know.
