2013 craftsman gold series 6.75
heamicdan
had this mower several year--does anyone know what operates auto choke? no signs of thermostat thing on exhaust no sign of air vane --- this has always run perfect untill i was shaking wet grass of blades and it stalled and refused to start---i assumed i shook something in carb loose --i bought a new one ---it will start 1st pull if i hold choke or use starter fluid--and will run perfect till its runs out of gas ---i just can't figure out the auto choke--190cc
dougand3
Need Briggs model #. Eg: 126M02. Near spark plug - maybe on OHV cover.
heamicdan
this is craftsman model--917.370412
i will go out and look for engine model
briggs serial----13 0910 58 59579 rear of motor
675 series---277009---near plug
Auto-Choke thermostat is located behind the muffler. Goggle “Briggs Auto-Choke system” for videos on how it works, how to adjust and how to replace.
heamicdan
yes i do know this but there is not one nor is there any signs there ever was one or the air vane-----and the mower has run perfect for years---was gonna order thermostat but no place to hook the slide end to and i won't believe both sections fell off
According to the model you posted it should have one, unless someone removed it. Did you purchase the unit new? Can you find and post the engine numbers? I’d like to see if the engine was swapped out.
heamicdan
i will look better and no i did not buy it new but i doubt the old guy i bought it from swapped out motor
dougand3
This may be an L head. Look above the muffler for XXXXXX-XXXX-XX 12345678.
Scrubcadet10
Moderator
Staff member
According to sears parts direct it's a 120k02_____ ______
dougand3
I've seen the 120k02 on sears part site on many different engines. I think it's a generic # they use to hide the engine. Sears is slimy that way.
