TylerFrankel1
- Feb 7, 2020
- Threads
- 16
- 124
Hello everyone! I haven't posted here for a while. Back last spring I restored my Troy-Bilt Bronco Tractor and posted a bit about it here. I ended up getting a job as a tech at a local mower shop which I've had for the past 8 months. Between my experiences at the shop and working on my own equipment at home, I've become pretty well-versed in small engine repair. Recently a customer gave us (most of) an opposed-twin engine. It's a model 42A707-1237-01 from 1993. When we got it, the cylinder heads/gaskets and blower shroud were off, starter and ignition coil were missing, airbox/filter housing and cylinder head cooling shrouds were missing, the bolts for the blower housings/shrouds were all missing, 2 head bolts were broke off in the block, some light rusting was present at the tops of the cylinders, etc. Bossman didn't want it (obviously, it's got a lot wrong with it, not worth shop time). I took it with me because I've never worked on an opposed twin and wanted to try a rebuild on it. Problem is, it's missing parts, and since I haven't worked on one before there could be parts missing I don't even know about. I'm creating this thread to share the process for anyone interested and to ask general questions for those knowledgeable about this engine.
I decided to check the internals before deciding whether or not it was worth fixing. I stripped it down and sure enough, everything looks pretty good. I kept track of which piston/rod/rod cap was from the upper and lower cylinders, and where each valve piece came from. The entire inside of the block does have a 'film' of brown crispiness to it as if it was running hot at some point, but the connecting rod bearings/crank journals are beautiful, and the cylinder isn't bad at all. The rings are in good shape. Camshaft is in decent shape. Piston skirts have light scoring, which is odd because the cylinder and rings are in such good shape. Some carbon buildup is present in ring grooves. At the very least I may be able to sell these parts. So far I've been cooking everything in my ultrasonic cleaner, getting parts to look nice. Then I'll order parts that are a bare necessity to get it to crank off some starting fluid:
Starter/bolts, Coil/Bolts, New Crank Seals/Oil Pan Seals.
From there, if it hits off nicely, I'll go through the carb, get the intake pieces and air baffles that I need, etc.
Here are pictures of the block and parts after cleaning (I think the con rods look almost brand new)
I was also wondering if anyone has advice/thoughts regarding:
The lack of compression release on this engine (seems as though cam has no mechanism to achieve this)
Will the slight markings on the lobes of the cam be an issue? (see photos)
when looking up PTO/Flywheel seals there is an option for a kit that includes "shims", or something. What is that and is it necessary?
Why do only intake valves have seals on this motor? Do they absolutely need replacement? I'm not sure if I can get them still.
How should I best clean the valve guides (assuming they aren't shot, I haven't checked)
Are the upper and middle piston rings the same? There are no identifying marks and they seem to be exactly the same in construction, thickness, etc.
Mixing connecting rod bolts isn't a big deal right (hehe)?
The little tabs on the side of the connecting rod and rod caps are match marks, and the rod is installed in the piston with the "42" number facing the same way as the notch in the piston, and the notch points at the flywheel, correct?
Removing Carbon from Ring Grooves
Removing Brownish film/sludge from sump and engine block
Cleaning intake/exhaust ports and valves of surface rust
Removing broken head bolts/exhaust manifold bolt/bottom air baffle screws
If cylinder honing is necessary (see photos)
What the "extra holes" are in one of the valve spring chambers (see photos)
What size bolts to get for starter/top blower housing/ignition coil
How to remove 'bands' of deposits around wrist pins where no contact was made with either rod or piston (see photos)
I've been using 'super heavy-duty degreaser' mixed 20:1 with water. Just noticed it says "do not leave tools exposed to cleaner for more than 5 minutes." This stuff won't eat through steel parts will it!? Hope I haven't damaged the metals.
Anything I might be missing or forgetting? Parts/procedures necessary?
Thanks!
Thanks!
