PTmowerMech
- Apr 16, 2018
- Threads
- 396
- 3,019
Poulan Pro PP5020AV chainsaw.
Compression at about 150. Good spark. Prime it, choke it, and it cranks and idles fine but bogs when revved up. Over and over, (having to crank it a dozen times or more) I finally starts revving without bogging. I'm opening it up trying to find that strokin sound, but after at least 1.5 turns and still not hearing it, I start backing it back down. Simply because it sounds like the RPM's were too high. I get about 1/4 turn back from where it started revving up without bogging, and it dies. Then no more start.
I pulled the muffler and seen what looks like a pretty good gouge in the piston (facing the exhaust port) On the intake side, I can see the slightest bit of where the cylinder is just starting to score.
From the time I started getting WOT without bogging, to the time it died was maybe 1 minute. I was thinking I may have overheated it. But since this only has a small air filter cover, , that only uncovers the plug and the carb, then air should've been getting around the head pretty well.
I didn't check the cylinder first, only the compression. After the fact, I can barely get 105 to 110lbs of compression.
Did I do something wrong? Or do things like this just happen with Poulan saws?
