ALL engines have bearings. The questions are: Which type ? And, what are they made of ?
Actually they don't HAVE bearings
They have bearing SURFACES but that is a different thing to HAVING a bearing .
But if it makes you any happier
To cut costs mower engines manufacturers no longer fit replaceable bearings or bushes and simply machine the Al-Si-Cu cases to act as a bush
Al-Si-Cu is a 3rd rate bushing material so any wear or partial seizure is very likely to render the entire engine junk .
BEcause of the propentency of Al to weld onto steel that makes the engine much more sensitive to low oil situations and in particular make them very likely to seize due to low oil when used on a slope, some thing that an engine with real ROLLING ELEMENT bearings would be affected by.
Top quality commercial mowers use horizontal crank engines that have a deeper sump so con run on substantially steeper slopes without damage .
Not a problem if you live on dead flat land.
My workshop is in the foot hills and just about very engine I split has substantial wear to the upper bushing surface
I have put in real bushes made from 85:5:5:5 to save the larger expensive to replace engines but the push mower engines just get replaced.
It is about the only used mowers I sell now days,  old 2 strokes to people with lawns too steep for modern 4 stroke engines .
The old Sprit engines seem to be able to handle slopes but the new OHV engines can die in less than  season.
