In this case the first thing I would check is to see if the the engine is running on both cylinders. Remove one plug wire and see if the engine starts. Repeat one the second wire. If the engine starts only on one cylinder then the other side is not firing. Second would be to see if the flywheel key is starting to shear.
Thanks for the reply however as stated this is a model 311 777 one cylinder engine I did check flywheel shear pin and it is in good shapeIn this case the first thing I would check is to see if the the engine is running on both cylinders. Remove one plug wire and see if the engine starts. Repeat one the second wire. If the engine starts only on one cylinder then the other side is not firing. Second would be to see if the flywheel key is starting to shear.
Somebody may have to correct me on this but Perhaps your spark is cutting out at higher rpms. Maybe your timing is wrong.Thanks for the reply however as stated this is a model 311 777 one cylinder engine I did check flywheel shear pin and it is in good shape
