breagler
The fuel gauge was working fine for the first 5 hours of use, it became erratic and would read normally once the mower moved around a bit. Now it shows empty with a full tank. Apparently this is nothing new to Hustler mowers from what I can see on most of the web sites. The dealer will pickup the mower tomorrow. My question is this, does the replacement sending unit or gauge fix this issue or will it come back once again? From what I see on other forums is this issue will return days or weeks later.
Stay safe out there!!
