14" Poulan Woodshark
Scrubcadet10
Moderator
Staff member
Working on a 14" poulan Wood shark Chainsaw, I can't find a model number on it anywhere so i can order the proper parts. all i can find are the emission tag numbers..
Anyone know where they put it?
Fish
Can you put up some pics?
the model and serial number sticker tag is normally below the trigger on the fuel tank. Seems like it was the same tag as the emissions tag but I could be wrong.
dougand3
Poulan saws normally have the model # on clutch cover, recoil housing or both. I have a wood shark model 1950. Post a pic of all 4 sides of your saw if don't find it.
Scrubcadet10
Moderator
Staff member
darn it, I didn't get a notification for this, I'll go snap some photo's.
Scrubcadet10
Moderator
Staff member
there it is! light from the flash helped, but it appears to be wiped out.
It is there scrubby
Take some photos of the tag in good strong sunlight
Then open a COPY of each photo in your favourite photo editor.
Play with the contrast settings and the numbers will jump out & bite you
You may need to get some from different photos
The dark area will respond better to inverting ( make negative on some apps ) .
dougand3
Scrubcadet, I have a 3-4 of these in parts boxes. When they have scored P&C, they aren't worth rebuilding, $-wise. What parts do you need?
