Am I correct understanding I do not have to remove condenser and points, just cut wire, install new moduleBriggs part number of the new module is 591420 Which is the magnetron style module.
Correct. I just normally remove the screws holding the old module and then pull the point wire out without removing anything else. If you decide to remove the points and condensor most of the kits come with the plug that you drive into the point plunger hole to seal it.Am I correct understanding I do not have to remove condenser and points, just cut wire, install new module
