mikesignal
Hi all. I'm trying to replace my stator and voltage regulator. Does it matter which way the wires go on the regulator from the stator, and then from the regulator to the wiring harness? The stator is not labeled , only the regulator is labeled, AC, B+, and AC. Thanks
