you tube mechanic
- May 1, 2020
- Threads
- 2
- 27
Seems to be a common problem, but not sure what else to do. Working on a Craftsman 21" self propelled / walk behind model number 917.377823. Briggs engine 7.0 hp OHV model 128602 0304 E1 for a neighbor. Mower cranks with 2 pulls when cold (first start) but after shut down to empty bag it will not start without some serious pulling 20-30 times and sometimes backfires thru carburetor slightly (pops). A quick google search returned a hit to make sure engine isn't low on oil as they Briggs have a safety mechanism if engine is too hot, oil level is correct, also same post told me to watch the butterfly valve on the carb. I pulled the intake off to see it and marked the plastic lever above it connecting to the auto choke/throttle cable. Post said B.F. valve will be open at first start but should be closed on hot start. This mower has valve open anytime the engine is off, valve open on cold start and open on hot start, but nearly closed and fluctuating with engine running. From what I can tell that seems normal as you don't have centrifical force to actuate the lever near the flywheel so the spring on the auto choke/throttle pulls the B.F vale in the open position when engine shuts down. I manually closed the B.F. valve after engine was hot and it seemed to start better with about 5 -8 pulls. Not sure if my info is bad or not. Should the butterfly valve be open at cold start and closed or partially closed at hot start? Next task is to pull the carbureator off and start cleaning it and the fuel bowl internals, but I am waiting to see if anyone else has feedback. Thanks for any info and suggestions.
