LX188 John Deere with kawasaki motor. Starter Solinoid problems.
tiger29
When pulling solinoid from starter and putting back in does it have to be back in there a certain way. having problems
The way you take it off goes back the same way.
What problem are you having ?
there is a little plastic tab on the solenoid with a groove in it, if you look at where the solenoid goes into the starter housing, you'll see a plastic piece with a slot cut in it, the plastic piece on the solenoid hooks into the plastic piece in the starter body.
i find it's sometimes easier to replace the starter as a whole.
