 - Feb 19, 2020
- Threads
 - 118
 - 12,657
Here is some good questions about your setup. What size and length of the air lines plus also are you using hi flow couplers and adapters? When I first got my Air Cat it wouldn't even remove a nut tighten to only 50 ft-lbs. I installed a pressure gauge at the impact and found that the line pressure was dropping to less than 20 psi even when the standing pressure was 125 psi. At the time I had M style couplers and adapters installed in the line with one at the compressor so I move it out the way when I need access to it for repairs. Once I upgrade to V style high flow adapters and couplers the I regain nearly full pressure at the impact even on a 100 ft run of 3/8 air line.A couple of days ago, this guy needed someone to take off one nut/bolt from a 5th wheel hook up he was selling. I went all the way up to the 3/4" air impact and it still wouldn't budge. So I cut it off with the cutting wheel. After soaking it in something all night, the next day, I had the bolt on the vice with a breakover and it still wouldn't budge.
So if your line pressure at the impact drops a lot even a 3/4 impact will not work at it best power if can't the pressure and CFM it needs.
The darn Campbell Hausfeld impact never worked right that I got from Wal-mart so I just gave it away.
