247.204110 Lift & height adjustment
PTmowerMech
Community Leader
Location
Arkansas
Something screwy is either going on, or I'm missing something here.
I've adjusted the deck height (left side) as high as it'll go. But it's still way too low. According to this diagram, every nut & bolt is in it's proper place. I don't see anything worn out.
Scratch all that. After getting under the front of the deck, I realize the entire deck was bent. What ever this dude hit, must've been pretty massive. With the deck lifted all the way up, the front left wheel was just barely off the ground.
