i just had to post this rant but im sure we have all had these mowers from time to time
i just bought a 2013 46" ariens mower to repair and flip, the ad said it wouldnt run but should be an easy fix. it was raining when i got there and i couldnt get that good of a look at it, but i could tell there was some jacked up stuff but being only 7 yrs old i figured it has to still be well worth putting a little money into it.
i could tell he messed with the wiring and rigged up a metal tractor gas tank and cut a fist sized chunk out of the plastic steering wheel upper housing to access the gas cap on it as well as removed the parking brake arm and lever to make room for the funky gas tank so i knew i was going to have to put a bit of work into it.
at first i thought the toggle switches and missing ignition switch was because the switch went bad but apparently he couldnt figure out the brake has to be pressed to turn the engine over so he took out the key switch and cut all the wires, and i mean all the wires, and added toggle switches to turn on things like the carb solenoid and starter solenoid and a kill switch so new wiring harness it is. then i get the steering wheel upper housing and wiring harness replaced and its finally a functional lawnmower again. i was lucky and bought a parts lawnmower with a good running engine, no deck, and a bad tranny for $20 to get all the parts and wiring harness i needed.
it looks like the CR went bad on the cam, so i need to pull the engine and fix that later but i just swapped it out for the running engine from the parts mower since they were identical.
so i move on to rewelding the cracked welds deck hanger bracket. i swear, when will people learn to drop the decks all the way when trailering lawn mowers. any way i flip the still nearly new deck over and lordy lordy, he has put new blades on it and welded the nut washers to the blades and then welded the nuts onto the washers because he apparently rounded the nuts off and welded everything together rather then buy new blade bolts for it. i have spare spindle shafts on hand so cost wise this mower turned out to not be a loser but the level of stupid involved in the things done to this 7 year old still new looking mower is shameful.
in the end, even though i put a lot more hours into it then i ever wanted or planned to, im still gonna make good money on it but only because i scored the perfect doner parts mower with everything i needed on it for $20.
