This plastic part, which the rubber o ring fits over, was cracked/broken all the way around so that it came away in two parts when I replaced it.
Thank you much for all the details! Since it cracked, I would expect it to leak fuel -- was it?
Take off your air filter and look into the throat, and then press the primer bulb firmly several times. You should see a pulse of fuel splash up with every button press. The gasket between the air filter base needs to be perfect for this operation to succeed, sometime beefed up with a little smear of sealant on the gasket sides.
If you see the fuel pulse up, and still no start, then your problems are elsewhere.
No. This part was the intake manifold that conducted fuel/air mixture from the carburetor to the engine valve.
Because it was broken/cracked, the vacuum developed by the piston sucked in air from the crack rather than atomized fuel/air mixture from the exit of the carburetor.
So---- no leak, but no fuel/air mixture for the engine to burn either!
Hope that enables you to visualize what was happening. And one other thing to check when the engine wont start.
I think you have the wrong carb, you shouldn't have a Choke and a primer....
I don't think the primer will function on a choke style carb.
www.partstree.com
