I know there has been a lot of talk about trimmer Line but does anyone have any experience with the Stihl X-Line. You can purchase the .095, 5lb spool, 1837 ft for around $40.
hi ric,whats up, i never used the stihl x line.instead, i'm running grass gator line @ 095 and have good cut and durability with it. but i dont do a whole lot of trimming, I try to tighten up the areas with the 22" and then whats left i trim it. can you ask one of your local cutters in your area if you can buy a small chunk from them and then test it out and see how you like it ? that way you don't have to drop 40 on a whole spool. btw hows the cubs running.
