PTmowerMech
- Apr 16, 2018
- Threads
- 396
- 3,020
If the carb needle and seat won't hold against the small amout of pressure a pulse diaphragm fuel pump puts out you have a carb problem. Is the tank located higher than the carb? Do you have a pressure tester? You should be able to hold carb upside down and it hold 7 psi applied to the fuel inlet. I think you are asking for a crankcase full of gas. A fuel pump should not affect the level of gas in the carb.
Funny you should say that. Because I finally got back around to this one like an hour ago. Was gonna adjust the valve because it was a little hard getting over the compression stroke. Pulled the plug and a cylinder full of gas shot out about 6 or 8 inches.
So that settle that. Off came the carb and a freshly rebuild one went on it.
The oil level didn't raise at all. So I cranked it up and let it run for a while. Barely a spit or sputter out of it. Which is surprizing. I'm not normally that good at rebuilding those nikki carbs. Guess I'm getting better.
If this keeps up, I might make a 3 by the end of summer.
P.S. I put a new pump on it also, and forgot to plug the air line into it, but it ran fine. LMAO... So what's the point of a fuel pump on a system like this, where the tank is mounted under the hood. (higher than the carb)
