I need to replace the reservoir, but not sure how you're supposed to get it out.
I have it completely disconnected, but it I can't see how to remove it.
It seems trapped by the welded frame members on the top, bottom and sides, and by the trannies in front and engine to the rear.
Anyone done this before?
Is there some trick that doesn't require removing the trannies or engine?
If not, which of those should I remove?
Thanks,
Steve
Thanks,
Steve
