Good afternoon.  Having a devil of a time getting this thing fixed so it will start when I mash the primer button a few times.  Mower starts just fine when I remove the air filter and give it a short squirt of ether straight into the carb.  Runs all afternoon, so that rules out fuel supply and ignition problems.
I need to see a diagram of how the primer line is routed to the nipple on the carb. I'm also unsure if I am missing any parts.
What is the INSIDE DIAMETER of the primer line that fits to the nipple on the carb?
Is Tygon line acceptable for use in primer line?
Does anyone know where I can find a good step-by-step instruction of how to remove the carb?. All the Videos I've seen about carb repair have the carb off already, or they are not specific to this model.
Lots of questions here, thanks very much.
