Rod in MN
I do have a 5hp. Briggs&Strattion engine on a wood spilter that a guy droped off for me to get running for him.
Back to the engine from hell i didn't get to hear it run they couldn't get it running i found the pickup tube in the bottom of the tank and springs unhooked and The Throttle rod weld up to make it longer. The Model# 130202 Type# 0878 01 Code# 81041410. The throttle rod comes out up on the top of the engine and has a slid chock. The carb is pulas jet w/slid chock and a fuel pump. I did checked the gov. arm and shaft that is ok. the spring from the Gov. arm to throttle pivot hangs losse. I can pull up or push on the throttle rod and the engine does not change speed? It looks like they made the link from the throttle pivot to the throttle shaft i do not know if it is right and i can not find one??
I would like to put a throttle cable on it to the throttle pivot and skip the gov. I can not find a service manual for this model
I did do some after Returing 15 years ago Not by choice. After 25 years as a John Deere service Tech. Mostly on Skid Loaders, Combines, Forage Choppers and Lawn Mowers. Also drove Semi deleverling and pickup Machinery for 5 years. It was the Skid loaders that did my back in. I have no disk left in my lower back.
Sorry it got so long
Thank You
Rod in MN
Thank You
Rod in MN
