Oil Drain
Anyone know what size fitting to use for an 24HP Briggs.I want to purchase a Drainz it hose for oil changes
I do not know the size, but Briggs makes two of their own drains. One is the plastic quick drain with the replaceable hose. The other is a permanent option which I had used on my 18hp Briggs. I have included a link to that hose. You can ask Briggs directly and they can tell you if it will fit up.
Thank you
