Denning12591
- Apr 14, 2020
- 3
Hey guys,
New to the forum, but I had a few questions about my mower. I've had it for about 3 years, has 172 hours on it now. Briggs and Stratton commercial 25hp.
What blades are yall running to get the best cut quality? I just ordered some Sunbelt XHT high lift blades to try out. I notice sometimes when mowing that I have sprigs of grass, or short lines that the mower will miss. I can usually just slow down and don't have the issue anymore.
Do yall run the recommended tire pressure the manual states? 25psi in the front and 1 in the rear?
I try to grease all my spindles and fittings every 20 hours or so, any other maintenance things yall recommend? I change my oil every 100 hours, along with air filter and fuel filter. Currently running amsoil 5w30 small engine oil and wix oil filter.
Last thing, how tight should the deck belt be when engaged? It seems like when the blades are engaged the belt has a lot of play when its spinning.
