247.288841 LT2000
Anyone ever replaced the short 41” spring tensioned v belt to transmission on one of these mowers? The current belt is worn/stretched causing the long ground drive belt to ride against the spring loaded tensioner arm which carries the pulley for this belt. This belt is trapped on the pulleys over the transmission with insufficient room against the frame walls under the seat for removal. Thanks.
