Thomas57
- Apr 6, 2020
- 7
The parts diagram shows that this engine should have a choke that operated by position of the throttle cable. Not a primer, but since we don't know what the guy put on it, the carb that he installed may be jetted too rich for that engine and air filters cause some restriction resulting in a rich mixture if already running rich.
the mower still has the primer button on it. I can take a picture of the new carb if that helps, but is there any solution if running too rich?
