lacrosse_24
I need to replace the carburetor on a Honda mower.
Model number: H662164TDA
Serial: MZCG 7724 132
imprinted on the engine is: GJAEA5781751
-How do I know which carburetor I need?
-Is it the same carb for all Honda gcv160 engines?
Thanks!
16100-ZOL-862 is the carb assembly and should cost about $16.00
Sorry I need all numbers when dealing with Honda, so I’m not the one to ask about cross referencing.
lacrosse_24
so how did you know which carb is needed? Did you go off the lawn mower model number, the serial number, or the number imprinted on the engine?
The sticker on the top of the engine says GCV160 but that’s it. No numbers or letters after that.
lacrosse_24
Used this number GJAEA5781751
Where did you look it up? Also totally unrelated question I need a control cable for this mower. I can’t find the model number. It’s been scratched off. Any ideas?
Used the Honda site. Give me a couple of pics of the entire unit and I’ll see if I can locate a cable.
I believe the OP is mis reading the model number here. Looks to be a HRR2164TDA which is a HRR216K4-TDA (SN: MZCG-7700001 - MZCG-7799999) and if so the carburetor comes as a 16100-Z0L-023
