honda hr215 hxa
rml6093
my mower is having several issues the first is when I try to engage the blade the engine cuts out. however if I slowly engage the blade it sort of bogs down and they engage along with the engine staying running.
second problem is a surging issue when I take it off of the choke and to the rabbit position.. a third issue in relation is that it doesn't seem to change idle speed when i turn it from rabbit to the turtle position and vise versa
any help would be appreciated thanks!
BHRS
If the engine is cold when I engage the blade it does the same as you are describing. I try to let it warm up for a couple of minutes and sometimes engage the blade and press for the choke at the same time - it helps for me.
I'm attaching an adjustment sheet for these engines. Look at the top one for the governor. Follow the instructions to set the adjustment. I will almost bet someone tried to pull more rpm's by "adjust" the governor and it's searching for the right rpm. The other possibility after adjustment is a problem with the governor itself. If the governor is sticking or worn out it will require removing the engine then pan to access the governor to replace it.
  • GXV140 Engine Adjustment Information.pdf
rml6093
That actually could have been my doings because I wanted to clean the pilot jet so I had to take the throttle stop screw out to get to it. I checked out the attachment and seems fairly simple but how would I know the right rpm though?
BHRS
It doesn't look like it's made for a single cylinder four stroke engine based on the choices.
This is identical to the one I use. I've had mine for 20 years and it works on 2-stroke and 4-stroke engines.
rml6093
Thanks for the recommendation but that’s a bit too pricey for me
HarmonySeeker
Check the condition of the bearing in the blade clutch. It may be failing.
