Deck issues
It sounds like you have bent the deck. What did you hit?
That’s really the only way that the blades can touch.
No that not it at all. This mower has a timed belt deck and the blades are out of time. One blade is to be 90 degrees of the other blade. Can the timing belt condition and replace if necessary and re-time the blades.
Now this is considering it has the 42" deck, now the 38" deck is non timed deck which then it can be damaged.
