Pull the head off and take pics. If only in the pushrod area and not messing with the cylinder there may be hope. If you are just venting crankcase vapor can probably fix it
What a D-bag. I would go back on the guy and show him the hole and ask how it ran just fine. Amazing how many unscrupulous retards inhabit the planet.
Actually the crankcase should be operating under a slight vacuum with low pressure pulses. I wouldn't be afraid to try something like JB weld.Actually probably fixable. JB weld or some alumaweld. You could even just cut the gasket and put a bolt in with gasket sealer. It is only sealing crankcase pressure not cylinder pressure.
