Gearjammer
I'm trying to get a donor motor started in a cub 126. Got spark at the plug. New carb that seems like it will work. Cranking the motor with spark plug out spins fine. Putting the plug in causes the motor to spin once and then quit. ( due to compression, I'm guessing) Battery seems good and so does s/g. Your thoughts, guesses, and observations welcomed and appreciated. Thanks. Gearjammer
