PTmowerMech
- Apr 16, 2018
- Threads
- 442
- 3,419
Most mowers will start and run without a blade. May have and erratic idle. The heavier flywheel or mower blade stores energy to help the engine not bog down when a load is applied.
Back in the day when i built 5hp Briggs go cart racing engines in the stock appearing and outlaw stock classes i would replace the cast iron flywheel with an aluminum one. Start and idle just fine and gave better acceleration out of a corner because engine didn't heve to put as much energy into the flywheel. Better deceleration into a corner because the engine would wind down faster and release the clutch sooner.
I hate those carbs. I have a mower in the shop right now with that carb and it came in for hard starting and surging. I have put 2 new carbs on it. When it starts it still surges a little but is nearly impossible to start. Valves are good and adjusted properly. Good spark, flywheel key good, new fuel. Head gasket good. I am not impressed with these carbs or the engines thay are on.
I'm about to take one apart again. I remember the float not being level. Not much. But enough to be noticeable.
Seems I watch a video about heating up and bending the plastic where the needle rests.
