Rickw
 - Nov 21, 2019
- Threads
 - 5
 - 35
Sorry for the double post. First time adding pics. I used 3/4” rubber stall mat as wing extensions. Bolting thru existing holes. 9”x7” pieces. Works pretty good so far
I"m using the turf tires. I have chains but fairly use them as they will tear up the pavement a bit. I try not to blow going down hill easier to get stuck)
if I do run into a problem, picking up the blower puts a lot of weight on the drive wheels and gets me out
