- May 6, 2010
- 11,994
That is where I found those numbers myself, although I almost missed it. Thoughts on pulling the heads and inspecting?
I would start with a leakdown test to see where you are loosing compression.
You use your ears. If the air from the cylinder is coming out of the air filter housing then you have a leaking intake valve, not to be confused with air that could be coming out of the breather tube connected to the air filter housing from the engine block, but this can be prevented by removing the dipstick. . If air coming out of muffler then exhaust valve leaking. If air is rushing out of the dipstick tube then that would be worn/damaged rings or blown head gasket. Some air coming out of the dipstick tube is normal since there will be air bypassing the rings to some extent. Also air leaking past the valve can mask worn rings or head gaskets issues.
You will need to pull the head in the end but it will give you some direction to what to look for.
Have you tried the plug wire pulling test??
It doesn't cost anything, and could tell you a lot.
Hell, it could just be a bad/fouled plug.
I once knew a guy that started to pull the engine on his truck, because the engine was "locked up". Turns out to be just a locked up alternator. Check the simple chit first.
