John Deere 320 Constant Scaping Noise
BuddyWho
Hi My 320 is making while running whether PTO is engaged or not a constant sound like scrapping.
I am thinking PTO went south,any ideas
mechanic mark
Look closely at idler pulleys & belts, may be bearing in deck idler pulley.
Glyn Robinson
did you find anything? i love my 320
tom3
If you have the noise with the blade off AND on it's probably not the clutch there. If it makes the noise with the drive brake/clutch pedal down, probably not the idlers under there. I'd look close for a stick or something jammed up under there. Maybe you can hear the noise more around the top of the engine? Could be something around the flywheel rubbing?
